Tractor Talk Discussion Forum
power steering fliud-jd 70
jubilee johnny
04-14-2008 05:23:47
What kind of fluid is used in the power steering of a jd 70 gas? Does it have to be jd brand?
David from Kansas
04-14-2008 10:31:58
 Re: power steering fliud-jd 70 in reply to jubilee johnny, 04-14-2008 05:23:47
AF2235R for the qt. bottle. $5.19, not cheap but highly recommended by the "experts".
Rich Va
04-14-2008 06:15:04
I guess you could use some other type of fluid but the jd ps fluid is highly recommended. Why take chances.
jubilee johnny
04-14-2008 07:04:01
 Re: power steering fliud-jd 70 in reply to Rich Va, 04-14-2008 06:15:04
That's true. I guess what I am really trying to ask is the type of fluid like hydrolic oil or is there a specific power steering fluid? Also, I live 80 miles from the nearest dealer and I need the tractor without a special trip just for that.
Mike M
04-15-2008 05:27:42
 Re: power steering fliud-jd 70 in reply to jubilee johnny, 04-14-2008 07:04:01
Well if you have to run it ? any oil is going to be better than NO oil ! I know of a few running around with ATF or Hy-Gard in them. When/if the leaks get fixed or system worked on may as well put the JD stuff in it to be sure. If it doesn't leak out then it is good for along time as I doubt many got changed very much due to the pain in the rear it is to do it.
Bob
04-14-2008 11:58:40
That power steering system is "tricky", at best. DO NOT scrimp on the fluid.
Heck, some $5.00 a quart isn't bad, nowadays!
Rich Va
04-14-2008 08:50:33
I can understand the situation. JD does have a specific ps oil for those old two cylinders. I have no idea what would match up to it in other brands.
BillinCentralMO
04-14-2008 19:30:47
 Re: power steering fliud-jd 70 in reply to Rich Va, 04-14-2008 08:50:33
I have a gas 70. It's a nice tractor. I was told by two different Deere mechanics , do not use a different fluid. I don't think it will work with something else. Get the Deere fluid.
