Tractor Talk Discussion Forum
TO20: anything to look for?
jose bagge
04-13-2008 16:15:18
Going to look at a ferguson TO20...anything specific to look for on these. Still 6V, supposed to be a good runner...
Nebraska Cowman
04-14-2008 09:43:07
 Re: TO20: anything to look for? in reply to jose bagge, 04-13-2008 16:15:18
Yup, I'm with jerry. Look for water in the oil. The blocks are prone to internal frost cracks. Heavy duty leak stop usually fixes them for a year or so and we just live with it.
Jerry/MT
04-13-2008 20:47:02
The Z series Continental engines that powereed the TO-20 and the TO-30 were prone to cracking if overheated. Makesure that there isn"t any water in the crankcase oil. T
The hydraulic sumps collect a lot of water from condesation with non-use (as do all the tractors of this era). Look for milky hydraulic fluid and make sure the the hitch can pick AND hold at least 300-400 pounds with the engine off. If it leaks down in 15 minutes or more that"s acceptable. When the oil is warm, the hitch should operate smoothly up and down.
Otherwise, it"s the same as any machine. Check the rad for signs of oil in the water, check the clutch, transmission, etc etc.
