Tractor Talk Discussion Forum
Rare Tractor Post
DickL
04-12-2008 10:26:01
Rare to me. In installing valve seat inserts in this head I broke thru the water jacket before I was as deep as the insert was thick. I have it bored out and ready for an insert that will be pressed in and fix the problem. It was a supprise though. Thought some would like to know about this.
third party image
Lanse
04-12-2008 12:12:24
 Re: Rare Tractor Post in reply to DickL, 04-12-2008 10:26:01
you got mail, dick
Lanse
04-12-2008 11:37:42
boy, that looks great!!!
DickL
04-12-2008 12:09:05
 Re: Rare Tractor Post in reply to Lanse, 04-12-2008 11:37:42
It will look better when it is done. I should have took a picture of it before I started. Valve were rusted in, seats were deep pit rusted, the exhaust ports were burned/washed out on both ends and it looked like some one had taken a hammer to face. A face cutter in the CNC with three setups, a fourth setup to bore the ports, a few minutes with a boat stone, a little time with an air tool and she looks like it can be saved. Add valve guides and valve seat inserts and she will cackle more than new.
Sid
04-12-2008 18:46:13
 Re: Rare Tractor Post in reply to DickL, 04-12-2008 12:09:05
"she will cackle more.." Been a long time since I heard, "pull back her ears and make her cackle"
J Schwiebert
04-12-2008 11:10:10
Been there and done that too. I had a "rush job" one time on a slant 6 that was used as an industrial engine. I had 11 of the 12 seats in. Next one I also found the water jacket. Also on a Case diesel head one time. Called "core shift. Did you ever do any 6.2 engines? You need to use a real thin seat on those. Looks like an intake there in your picture, how deep was the counterbore? What kind of seat cutter do you have? J.
DickL
04-12-2008 11:52:06
 Re: Rare Tractor Post in reply to J Schwiebert, 04-12-2008 11:10:10
I had the stop set at .160 and the opening into the water jacket was at .074. I had a .250 insert and thought I could seal it with the thicker insert. No way. I bored on down so I can cover the hole. I know it is not a problem that will cause a problem just have to turn up an insert next week. If I can find a cast iron pipe I would like to turn it down. I will probly end up making it out of prehard 44 H 13 tool steel. I use that in the tool shop for mold inserts. It is bar stock and will take a bit more time because of having to bore out the center, cast iron pipe just needs the outside turned and a reamer run thru the center.
The counter bore cutters are carbide mandrel guided to the valve guides.
