Tractor Talk Discussion Forum
Headlights for 1996 GMC Sierra
Bruce Hopf
04-10-2008 23:31:10
Can any body tell me how to adjust the head lights on a 1996 GMC Sierra pick up truck. I foud two hex adjusting studs, on the top of the head light. Is there adgusting studs on the bottom of the head light to push the light beem up? Right now, aperson could use the truck to hunt dew worms. I tried to adjust the head light on the drivers side, and I turned the adjusting stud until one came out., The one closest to the fender, and the head light beam wouldn't move up. Your help is greatly appreciated. Thanks. Bruce.
glennster
04-11-2008 05:43:29
 Re: Headlights for 1996 GMC Sierra in reply to Bruce Hopf, 04-10-2008 23:31:10
on your series, the two long vertical torx bolts hold the headlamp asems in the housing, to remove the headlamps to change bulbs, you loosen those, pull em up and out then re-bulb. there should be either two torx head bolts or two adjusting knobs also to handle the aiming. look for one below the headlamp way back in there. some you need a special long torx driver to adjust heres a pic of the torx driver
third party image
dave2
04-10-2008 23:36:32
Might try this place, or just google it.
Good Luck,
Dave
http://www.truckforums.com/forumid_25/tt.htm
