Tractor Talk Discussion Forum
need help bleeding hydros on kubota b 6100e
brandond
04-10-2008 18:00:40
can anyone tell me where to bleed the hydrolics on my kubota b6100e. i beleive ther is air in the line and i dont know where to bleed them at. thanks, brandon
MSM
04-11-2008 01:56:38
 Re: need help bleeding hydros on kubota b 6100e in reply to brandond, 04-10-2008 18:00:40
There is no bleed provision.Assuming the unit is in good shape normal oil flow will force out any air.If it is buzzing or not functioning properly,it could be a leak on the suction side of the pump,stuck relief valve,worn pump or motor,clogged filter,improper oil etc.You need to do a pressure test on the system and then follow the problem diagnosis proceedure in the manual or send it out for repair.
brandond
04-12-2008 19:17:32
 Re: need help bleeding hydros on kubota b 6100e in reply to MSM, 04-11-2008 01:56:38
how do you do a pressure check on the system?
