Tractor Talk Discussion Forum
oil problem
big tomato
04-08-2008 20:26:59
oil level keeps going up on my ih 300 utility. smells a little like gas. i always shut off the gas when not in use.
big tomato
04-09-2008 14:51:36
 Re: oil problem in reply to big tomato, 04-08-2008 20:26:59
thanks for the help. i will start checking all out.
Codie
04-09-2008 12:26:40
My JD B did that. The float in the carborator had a hole in it and was not functioning properly. It ended up filling the crank case with gas.
IH2444
04-09-2008 08:41:54
might smell like gas from running rich, but the cause might be hydro oil leking in from the hydraulic pump shaft ?
Kentb of SWMO
04-09-2008 07:44:14
If tractor has a mechinical fuel pump, check the pump. It may be leaking GOLD, I mean gasoline, into your crankcae.
Kent
04-09-2008 04:27:25
Leaking fuel pump gasket. Fuel in the cylinder is so insignificant that you would have to run a long time to see alot on the stick.
Bob
04-09-2008 05:34:58
 Re: oil problem in reply to [email protected], 04-09-2008 04:27:25
You posted: "Fuel in the cylinder is so insignificant that you would have to run a long time to see alot on the stick."
NOT nesessarily true, especially in cold weather, or if the engine doesn't have a working thermostat, and is not warming up.
"Leaking fuel pump gasket."
I could be wrong, bbutI don't think this tractor uses a fuel lift pump.
Bob
04-08-2008 20:59:27
Maybe a dumb question, but is it misfiring? If one cylinder is "dead", the unburned gas from that cylinder will get into the oil.
Not quite sure how that one is set up, but are you SURE it's not losing hydraulic oil, and gaining engine oil?
dave guest
04-08-2008 20:34:43
Is it time for oil change. Do you run the choke too much, or never get it warmed up? You can block radiator with cardboard for short runs and cold weather.
