Tractor Talk Discussion Forum
Smoking Cub Cadet LT1018
Michael Mulliga
04-06-2008 10:29:31
This message is a reply to an archived post by Chad Voci on June 07, 2005 at 12:38:45.
The original subject was "Smoking Cub Cadet LT1018".
that happened with mine and it does that on a hill because the oil level is to high I was told to remove a little oil and keep it below full a little bit about 1/16 of inch and it helped me. good luck
Tom Fellion
06-08-2008 11:18:57
 Re: Smoking Cub Cadet LT1018 in reply to Michael Mulligan, 04-06-2008 10:29:31
Just got my LT1018 back from cub cadet shop. It too had saem problem you described. Turned out mine blew a head gasket and then wore down one of the Lobes on the camshaft. And my cub only had 94 Hrs on it.
I recommendthat if you have a compression gauge you pull the plug and do a compression test. When mine started smoking I too removed a bit of oil thinking it was overfilled.
Boy !! Did I pay the price. $352.44 for the new head gasket, camshaft and milling the warped head.
