Tractor Talk Discussion Forum
1995 Caterpillar D5H Series II
Henry Caswell
04-05-2008 13:15:12
Have problem with hydraulics. While operating the dozer, I lost pressure on the lift of the blade but still have pressure to the tilt cylinder. Switched the control valve body assys and still have the same problem. Any and all info will greatly appreciated.
Ole Dawg
04-05-2008 17:26:15
 Re: 1995 Caterpillar D5H Series II in reply to Two Dogs, 04-05-2008 13:15:12
Maybe you popped a piston seal in one of the lift cylinders, and the oil is bypassing. This could cause the lift to stop working.
RodInNS
04-05-2008 14:10:11
 Re: 1995 Caterpillar D5H Series II in reply to Henry Caswell, 04-05-2008 13:15:12
If you hold the tilt lever hard over, and the lift hard back, will the blade lift when the tilt strokes out?
I suspect it will... If it does then there is a load sense problem in the system somewhere.
I'm not up very well on those systems but my '87 4H has a fairly basic CCLS hydraulic system. If yours is pilot controlled then there's probably a problem somewhere in the pilot circuit.
That's not much help but a couple ideas....
Rod
