Tractor Talk Discussion Forum
Allis Chalmers WD45 transmission trouble
Raymond Miller
04-04-2008 12:32:20
I have a Allis Chalmers WD45 that jumps out of gear when pulling sometines as well as when you turn down a hill. Can any one give me any advice on what to do to solve this problem. Thanks Raymond
JMS/.MN
04-04-2008 18:35:01
 Re: Allis Chalmers WD45 transmission trouble in reply to Raymond Miller, 04-04-2008 12:32:20
Easiest thing to check is the condition of the shifting forks and the bottom end of the shift lever. They are over 50 years old, usually worn...can be built back up to original specs. Take off the battery box, unbolt the tower and inspect. Shafts and gears within the transmission are also very worn by now, but that involves major surgery.
big jt
04-04-2008 17:09:05
Rebuild the transmission.
Your blocking rings are worn out.
jt
