Tractor Talk Discussion Forum
O/T Scrap prices in your area.
Turke Bros. Far
04-02-2008 07:47:06
I took an old tandem dump truck in, I got $265.00 per ton. Thants the HIGHEST I have ever seen it. Some people were telling me it might hit $500.00 Hate to say it but there will be alot less projects sitting along fence rows with prices like that. What are the prices in your area?
old
04-02-2008 17:08:42
 Re: O/T Scrap prices in your area. in reply to Turke Bros. Farms, 04-02-2008 07:47:06
Yep and the sad thing is most of it goes to China. I just hope they don't do like Japan did before 1941 when they where buying scrap iron and we then found out 50% of it was going into there war machines. And yes its getting to the point and old tractor like say a Farmall H is worth more as scrap then it is in good running shape
HossinMe
04-02-2008 16:57:13
240 per ton No.1 prepared in Maine. Hoss
reid5365
04-02-2008 13:16:03
Im Outside of Louisville Kentucky. I want to scrap a wagon runnin gear with no wheels or tires on it and 4 insecticide and 4 herbacide boxes with mounting parts. How much do you think this would bring??? Thanks
Old Roy agiin
04-02-2008 11:45:43
#1 heavy copper $3.05 a lb.--#2 heavy copper, $2.80 a lb.--Red brass $1.30 a lb.--yellow brass $1.20 a lb--clean radiators $1.30 a lb --dirty rads. $1.05 a lb.-- copper / alum.cores $1.20 a lb,--alum cans, $0.80--alum. scrap/siding $0.75 a lb,--cast alum. $0.65,--stainless,$0.80 a lb the rest of this is per [cwt]---plate and structural,$11.50.---#1 prepaired iron,$11.00,--#1 unprepaired iron/steel,$9.00---sheet iron & shreaders $7.50---cast iron $7.50---clean motor blocks, $10.50---dirty motor blocks,$9.00---mixed misc.$7.25---#1 pressing,$8.50 THIS INFO WAS TAKEN FROM LOCAL PAPER. the companey that is buying for these prices notes prices are subject to change. Their website is.---www.pjgreco.com. WE are from SW PA
J.T.L.
04-02-2008 10:40:45
Took a pick-up load in last week of what they called "Light Iron". Got what amounted to $234.00 per ton. Had 1160 pounds on the truck, and got $99.00 for the load. That was here in York Pa.
John
OliverGuy
04-02-2008 10:21:32
Tin/baling was $200/ton last week and short iron was $230 I think. This is NW IN.
edj856
04-02-2008 08:55:59
A load of #1 prep steel brought 13 cents per pound in southern NJ about a week ago.
flying belgian
04-02-2008 08:00:00
hauled a load of unprepared last week. $143 in south central Mn.
Mathias NY
04-02-2008 07:51:32
I took in a load of short-steel over the weekend, $180/ton.
