Tractor Talk Discussion Forum
tire coating
amo
03-30-2008 17:49:35
what is the product to put on tires to make them look newer and where can it be purchased?
Paul from MN
03-31-2008 12:06:34
 Re: tire coating in reply to amo, 03-30-2008 17:49:35
I use Tire Foam. It is made by the same folks who make Armor All. You just spray the foam on the tire, let it sit a few minutes. The rinse it off.
Works very well. Protects from UV rays, and the tires look like new. It does make them SLIPPERY, so you would not want to do this then try loading onto a trailer.
gene bender
03-30-2008 19:23:16
Iscrubbed them first with soap and water using a stiff brush then applied MILLERS stuff even gave them two coats. It will cover lots of small cracks and so forth.
Don L C
03-30-2008 19:08:07
Miller Tire Co..... .419 335-7010
Black tire paint = like new tires
water base....mix it 50/50 with water wont rub off even when wet...$30 a gal....$15 a qt....Don
dave guest
03-30-2008 17:59:36
Used to be called tire dressing. Used to be found at Western Auto stores. Don't know where you are. Was long time ago.
Dave_Id
03-30-2008 17:57:56
There is a product you can buy at any auto store, sprays on like a foam. No wiping. Miller Tire sells a paint that you brush on which is permanent.
