Tractor Talk Discussion Forum
Anybody have a Kubota 105 or 125?
OliverGuy
03-26-2008 12:19:26
Just wondering if anyone had a 105 or new 125 and how they liked it. We"ve always had smaller ones at work and just wondering what everyone else thought.
Mn Dave
03-26-2008 17:55:36
 Re: Anybody have a Kubota 105 or 125? in reply to OliverGuy, 03-26-2008 12:19:26
Bought a new M105X MFWD in Dec. of '06 (now replaced with the newer model M108X), and now have 275 hrs. on it. It has the Kubota self leveling loader and just love the tractor or I should say my wife also loves it. We use if for feeding large round bales, feed grinding, spraying, cultivating with a JD 8 row 36" cultivator, and did do some chisel plowing last fall with it pulling a 9 point DMI chiesel plow. The M105X has all the same bells and whistles as does the M125X, except the 105 uses a 4 bangor engine with 16 valves, turboed, intercooled and is very spunky. I have the cast rear wheel centers plus fluid in the rear tires and it weighs in at 12,500 lbs. It is plenty heavy for going anywhere you want with a large round bale. I would recommend a Kubota. The power shift is great.
Mn Dave
03-26-2008 18:06:42
 Re: Anybody have a Kubota 105 or 125? in reply to Mn Dave, 03-26-2008 17:55:36
Mn Dave said: (quoted from post at 17:55:36 03/26/08)
Forgot to add, if you are comparing a M105X, then you have to compare it to the new M108X tractors as they are the same, just the engine was changed some to make it fit into CA. emissions controls. The M105S is a lighter model but the same horse I believe.
Ken Macfarlane
03-26-2008 13:16:24
Some better discussion in the todays tractors section of the site.
They are light like a JD 5603, actually heavier than that model but certainly not a tillage tractor. They are good pto machines, haying, dairy work etc. The 105 is a barebones kind of affair with a reverser and hydraulic clutch. The 125 is a nicer powershift model but you pay more for it.
Make good loader tractors, tend to last well and be easy on fuel since they are so light. Just don't expect the same weight as a traditional big machine.
