Tractor Talk Discussion Forum
IH 2pt plow
Kenny Valle
03-25-2008 18:09:22
Im looking for a 4bottom 2pt plow for 806 whats a fair price 16185534607 thanks
Mark Willis
05-08-2008 07:08:15
 Re: IH 2pt plow in reply to Kenny Valle, 03-25-2008 18:09:22
We pull a 4-14" with a 756. 6 suitcase wieghts balance it out nicely.
flying belgian
03-25-2008 20:06:12
I sold mine last summer for $300 and I was satisfied.
matthies
03-25-2008 19:53:46
Where are you located? I know of one but don't know if the guy will sell it and its been sitting outside for quite some time.
Kenny Valle
03-26-2008 02:43:43
 Re: IH 2pt plow in reply to matthies, 03-25-2008 19:53:46
East central ill at Robison .email doesnt work right call if you 100 mi or so away
Goose
03-25-2008 18:57:09
In a four bottom, you might want to consider a semi-mounted.
I bought a four bottom 3 pt. John Deere plow once and put it on an 856. I made a half dozen rounds, took it back, and traded it back for a semi-mounted. The three point was just too much weight swinging around behind the tractor.
Most 3 pt and two point implements have the majority of the weight tucked in right behing the rear wheels, so it"s manageable, where a plow sticks clear out behind.
If you insist on trying it, you"ll need a LOT of weight on the front end of the tractor.
My two cents worth.
Allan In NE
03-25-2008 22:28:58
 Re: IH 2pt plow in reply to Goose, 03-25-2008 18:57:09
Naw,
Think you just weren't used to it maybe?
An 856 would simply play with a 3-bottom plow.
They "look" heavier than they really are. Not nearly as heavy as a 6-row cultivator or a loaded planter.
Allan
third party image
third party image
sd pete
03-26-2008 07:09:46
 Re: IH 2pt plow in reply to Allan In NE, 03-25-2008 22:28:58
Is that a 92 lister?
Allan In NE
03-26-2008 07:30:13
 Re: IH 2pt plow in reply to sd pete, 03-26-2008 07:09:46
Naw,
Surface with the shoes.
Allan
third party image
sd pete
03-26-2008 07:32:27
 Re: IH 2pt plow in reply to Allan In NE, 03-26-2008 07:30:13
These old eyeballs don't work the best anymore.
steveormary
03-26-2008 06:29:07
I had a semi-mount 4-16 on the fast hitch with mechanical lift assist. Pulled it nicely with my 706 ger.
steveormary
