Tractor Talk Discussion Forum
12 volt wiring hook up
Brent Petersen
03-22-2008 10:40:08
I converted a 1948 8N to 12 volt, however the instructions on how to hook up the wires from the alternator were very poor. If I hook it up so that alternator charges the battery, the battery will drain when the tractor is shut off.
Any tips would be appreciated.
Janicholson
03-22-2008 12:28:38
 Re: 12 volt wiring hook up in reply to Brent Petersen, 03-22-2008 10:40:08
third party image
This will do it, your ignition switch may look different, but it is correct for an SI 10 delco. JimN
jdemaris
03-22-2008 11:02:42
It depends on what type of alternator. You cannot have fulltime power to the field/exciter terminal of the alternator or it will drain your battery. It needs to be switched either electronically or mechanically. This is usually done with the ignition switch wiring - unless you've got an electronic self-exciting regulator.
