Tractor Talk Discussion Forum
4020 power shift woes
Madbohemy
03-18-2008 19:59:35
I've got a 1964 4020 power shift. Last fall I was pulling a 400 bushel load of corn up a n incline in 8th gear. When the tractor pulled down to about 3/4ths the rpm the transmission acted like it shifted to sixth gear. I manually shifted to 6th gear and pulled the rest of the way up the hill. I used the tractor to round bale about 200 corn stalk bales and found the transmission to be slow and sluggish, plus the pressure guage on the dash would drop with the rpm. This is not normal with past performance. The pto works fine, but a wanna be mechanic installed a new pto clutch about 500 hours ago. Should I pull the clutch pack out and take it to a dealer for inspection? The tractor is already split. I checked the torsion plate at the fly wheel and it's okay. I haven't had the tranmission pressures checked, I probably should have but money is tight. Any ideas? Thanks.
db990
03-20-2008 11:57:16
 Re: 4020 power shift woes in reply to Madbohemy, 03-18-2008 19:59:35
This is just a suggestion. We have a JD 4520 power shift that had gear issues. It turned out to be that the gasket to the valve body had some small tears in it that was allowing fluid to blead through and not allowing the right amount to keep the transmission tight. It was a simple cheap fix. P.S. it was the origional gasket over thirty years old.
DLM
03-18-2008 21:09:03
If you have it split between engine and bell housing i would take C1 and C2 clutch pack out & check it out you can also check the trans. pump at the same time,there are 4 sealing rings in the manifold that could be worn,check your clutch plates for ware & worpage.The PTO clutch won"t have anything to do with the trans. part not working right you have to split it between the bell housing & trans. to get to the PTO clutch.
Make sure the suction screen in the bottom of thr trans. is clean & your filters. Don
Ron Anderson
03-18-2008 20:27:49
you can buy the clutch packs at a tractor salvage dealer used. A good place will check them before stripping the tractor to see if they are good. It would have been best to put gauges on yours before you split it so you knew what the problem was. now you will be. guessing.
rexhellwig
03-19-2008 10:59:28
 Re: 4020 power shift woes in reply to Ron Anderson, 03-18-2008 20:27:49
My own observations:
-Number of years working on Deere powershifts - 28
-Number of junkyard, "rebuilt", or "reman" C1C2 and planetary packs I have seen installed - too many to count
-Number still in service after 500 hours - 0
