Tractor Talk Discussion Forum
Montgomery Wards Air Compressor
Aaron
03-18-2008 09:00:43
I recently purchased a small used air compressor from an estate auction. All the items at the auction were owned by an elderly gentleman and all came with the original operator"s manual. I got a 1hp, 12 gal, 5CFM compressor for $20 and didn"t think that was too bad. It is a Montgomery Wards model 6557.
I would like to obtain any information I can about the pump itself as far as manufacture, if the rate can be increased, etc. It appears in great shape and just want to make sure everything is "up to snuff" with the proper oil and proper preventative maintainance.
Any informaton you can share with me would be greatly appreciated. Thank you for your time.
chvet73
03-18-2008 22:03:32
 Re: Montgomery Wards Air Compressor in reply to Aaron, 03-18-2008 09:00:43
Had one from Wards that I sold a few years ago. It was a Cambell Hausfeld. Went on their site and found a model which looked like it. Was able to use that for a parts guide. They haven't changed the basics to this day. Most of the parts will intercahnge. We have a local motor/compressor shop, he took one look at it and was able to get any part I needed for it. Only reason I sold it was because it was 220v only. That kinda limited its usefulness.
Steve A W
03-18-2008 19:26:46
Aaron, Use SAE30 non detergent motor oil in the crank case, Replace the air filter element
and drain the moisture from the tank often ,
and it should last a long time.
Steven f/AZ
03-18-2008 10:52:02
Boosting the output is a good way to make a short life for the pump, valves, motor, etc.
Those old compressors that ran nice and slow didn't put out a lot of air, but they'll run nearly forever! What you have is probably a collectible...
Walt davies
03-18-2008 10:34:43
Aaron, it is pretty much all you get out of it so if you want more you will need to get a bigger one.
Not sure who made them but MW is Kaput so you have an orphan and when its gone it pretty much gone as parts if available will cost more than a new one will.
One thing these older pumps if taken care of will last just about for ever.
Walt
Vern
03-18-2008 20:50:47
 Re: Montgomery Wards Air Compressor in reply to Walt davies, 03-18-2008 10:34:43
Aaron;
I have a Montgomery Wards compressor unit & I'm pretty sure the compressor is a Campbell Hausfeld.
Vern
