Tractor Talk Discussion Forum
Electrolysis revisited again
flashback
03-17-2008 19:45:54
Lets go over some electrolysis facts. I have a constant 12 volts at 10 amps going to the system with the positive to the outside and the negative connected to the piece to be cleaned. I have 25 gals of water in which i placed 25 tablespoons of sodium carbonate. The positive side hasa two strips of steel opposite each other with the piece to be cleaned hanging between thm. What and when can I expect anything to happen. the current causes the water to move around ccwise but no bubbles. Please enlighten me as to the correctness and what results should be when. Jack
jose bagge
03-18-2008 15:52:59
 Re: Electrolysis revisited again in reply to flashback, 03-17-2008 19:45:54
man o man- I thought this was gonna be a discussion about how to remove the hair from my ears, or women discussing brazilians....
led
03-18-2008 13:48:23
BTDT! Just use vinegar & water. You don't have to clean all connections. Try side by side containers and keep track of time spent on electr. vs throwing in bucket of vinegar. Let us know!!!
Led
Nolan (foxtrapper)
03-18-2008 04:32:13
The size and cleanliness of the annode is crucial to how it works.
I hadn't realized how significant this was until I started puttering around with it more based on the advise I got here because of my lousy initial results (tried a piece of rebar as the annode at first).
Rex in Australia
03-18-2008 02:29:31
Hmm, should be working ok, sounds like you have done it correctly to me. Try putting the part closer to the anodes. Generally increases the current flow and hence - bubble action!
God Bless,
Rex
kyleOH
03-17-2008 20:39:01
Link
helped me out alot.
flashback
03-18-2008 10:33:47
 Re: Electrolysis revisited again in reply to kyleOH, 03-17-2008 20:39:01
would more anodes make thew system work better? Must the anode be the same size (length) as the diode. Would extra metal hanging in the solution be better? Read all the other stuff but my brain just doesnt compute unless it is a direct statement. Jack
