Tractor Talk Discussion Forum
1850 oliver
rats
03-17-2008 17:35:00
i have a 1969 1850 oliver gas that runs good but at high rpm it vibrates.in gear or neutral ,clutch in or out.
rrlund
03-18-2008 07:08:17
 Re: 1850 oliver in reply to rats, 03-17-2008 17:35:00
Hang on here,you said clutch in or out. Check the harmonic balancer (engine front pulley) The crank is slightly tapered on those,so if that big bolt is loose,she'll wobble like a knob on an outhouse door.
bradk
03-17-2008 21:38:18
Take off the chain coupler at rear of hydra-power or over/under(depending which you have)and see what it's like.
Start there and let us know.Heck,you might even find that the chain coupler is shot,or the gears are out of align.~brad
rrlund
03-18-2008 06:55:04
 Re: 1850 oliver in reply to bradk, 03-17-2008 21:38:18
Yup,the chain went to crap on my 1550 last summer while I was raking hay. The thing shook so bad,it shook a big leak in the radiator.
pork
03-17-2008 18:21:43
check some easy cheap stuff before goin in to deep. 2 tings that happened to me on different tractors were, front engine mounting bolts had worked loose. the other was a missaligned hydra-power to trans imput gear. the chain still fit, but turning the hieght ajustment bolt under -neath cured the problem.
craftsman
03-17-2008 18:07:27
Be more specific. The sheet metal vibrates,the clutch vibrates,the engine vibrates, what specific part or piece is vibrating----craftsman
rats
03-18-2008 16:47:20
 Re: 1850 oliver in reply to craftsman, 03-17-2008 18:07:27
it vibrates on the floor ,fenders and steering wheel. when rpm is above 1700
