Tractor Talk Discussion Forum
Remove paint from plastic?
Mark-Mi
03-15-2008 08:12:38
third party image
How do I safely remove from this plastic knob? Thanks guys ~ Mark
Mark-Mi
03-16-2008 09:03:29
 Re: Remove paint from plastic? in reply to Mark-Mi, 03-15-2008 08:12:38
Thanks for all the replies. Dick interesting company you have,I trust your knowledge in plastics or resins should I say.
Mark
Eric SEI
03-15-2008 11:34:50
There is (or was) a product called "Unpaint" that is sold at model railroad shops that is intended to safely strip paint from plastics.
Dick L
03-15-2008 17:35:27
 Just A Tidbit in reply to Eric SEI, 03-15-2008 11:34:50
Thermoset plastic is technically not a plastic. It is a phenolic resin which does not melt. Bakelite is a company trade name and even though other company's manufacture the same type resin under other names it is most often called bakelite regardless.
Bob85355
03-15-2008 09:12:21
I put parts like that in a pan of hot water until the paint loosens, usually about 8 to 10 minutes.
Bob
msb
03-15-2008 08:55:46
Try Goof Off or Goo Gone. Won't hurt the plastic. Available at all fine Wal Mart Stores
Leon R
03-15-2008 08:31:21
I would sand it smooth with progressively finer wet dry paper, finishing with 2000 grit and then polish it up on a rouge wheel.
mixaplix
03-15-2008 08:25:10
you can try a bit of brake fluid (test a smal spot first) with that said,can you just sand it smooth and prime and paint it rather than trying to remove whats on there?
DickL
03-15-2008 08:57:32
 Re: Remove paint from plastic? in reply to mixaplix, 03-15-2008 08:25:10
That is made from thermoset plastic. Same type of plastic used on cooking pot handles and lid knobs. Also distributor caps. A soft wire wheel can be used with care as well as sand paper. It does not melt with a little friction. Stripper does not melt it either.
