Tractor Talk Discussion Forum
12 valves?
Dan-IA
03-13-2008 07:21:36
Just a quick question, since we're talking about engines and mpgs and stuff.
Yesterday we went to the sale in Pocahontas and we were watching a little pickup sell. Nissan truck, wouldn't start - either dead battery or brake or neutral safety switch malfunction. Anyway, the engine said it had 12 valves. I was a 4 banger engine, so I'm confused. 2 valves are good for intake and exhaust. What's the third valve for?
(I could see the use of a third valve in the new engines that can shut down half the cylinders for better fuel economy-but on a 4cyl?) Most everything I've worked on says either Case, IH, or GM on it though. This has to be a weird Nissan gimmick.
Bob M
03-13-2008 10:12:04
 Re: 12 valves? in reply to Dan-IA, 03-13-2008 07:21:36
No wierd gimmick. As pointed out below some current production Ford engines use a 3 valve head.
It's not exactly a new idea either. Back in the 70's the Honda CVCC engines used a 3 valve/cylinder setup. As I recall it had 2 different-sized intake valves. The larger ome admitted a relatively lean main mixture; the other admitted a small volume of a richer mixture. I presume this was done to reduce emissions.
And going back to the late the 1930's the IHC "gas start" diesels also employed a 3 valve arrangement. However on these engines a smaller 3rd valve was used only during starting to open up spark plug chamber and to lower the compression ratio.
Hal (WA)
03-13-2008 14:30:34
 Re: 12 valves? in reply to Bob M, 03-13-2008 10:12:04
Some Dodge Colts (actually manufactured by Mitsubishi) also had 3 valve per cylinder engines too. The second intake valve was very small. It was my understanding that the small valve carried a different mixture of air/gas than the larger intake valve, and the whole idea was to deal with hydrocarbon emissions while still using a carburetor. I don't remember if the small valve controlled a richer or a leaner mixture than the larger valve.
My 79 Colt hatchback got very impressive gas mileage and ran real well. But I remember that later I had some carb trouble with it, and it was one of the most complicated carbs I ever worked on.
A few years later, the emission standards got more restrictive, and the manufacturers decided to go to computer controlled electronic fuel injection. I am sure that move was one of the reasons that vehicle prices went up so much, but in my opinion, going to injection was overall a good move.
Dealing with the emissions regulations forced the manufacturers to change their products, which they did in gradual steps. I think they continued to use carburetors on lots of models because it was cheaper, and allowed them to put out a lower priced vehicle. But as complex as the carb on that Colt was, I bet the carb was one of the most expensive components on that car, and probably not all that much less expensive than the later fuel injection.
A buddy of mine had an early 80's Datsun pickup with a 4 cylinder engine that used 8 spark plugs. He never mentioned that it had more than 2 valves per cylinder, but I remember the engine as looking fairly exotic at the time. He claimed to get well over 20 mpg with that pickup in normal driving, which was better mileage than others were getting with their mini-trucks. The other thing I remember about that pickup was that it rusted worse than anything else around other than 73-76 Chevy pickups, which must have been the absolute low in Detroit's rust protection.
Some later vehicles had more than 2 valves per cylinder, like the GM Quad 4, and the 4 valve versions of Ford's 4.6 OHC V8. I think that most of them were given the extra valves so the smaller displacement engines would yield more horsepower. If you check the specifications on most of the 4 cylinder engines currently produced in cars, almost all have 4 valves per cylinder, and give horsepower ratings that exceed what lots of V6's did 10-15 years ago.
Aaron Ford
03-13-2008 09:57:28
Nissan used to run the Z24 (?-90) engine until the early nineties. It had 8 valves, but also eight spark plugs. One fired on ignition and the other fired on the deadstroke. Actually produced more power. Not sure why or how, but it was a clean running engine. The engine you speak of is the newer KA24-E (91-97?). It has as said before 2 intake valves and one exhaust. The trucks were tuned to produce peak torque at 3500 and are quite powerful unless saddled with heavy options (4x4, extended cab, auto, a/c, p/s, etc...). I have timeslips from mine running a 16.1 second quarter when it was new. Not sure what it would do now. It will still get up and go, but running a truck with no auto, a/c, and p/s is getting kinda old. Paid 7900 in 1995 and still driving it to work every day.
Aaron
greygoat
03-13-2008 09:48:15
Mitsubishi Montero's had a 3 valve per cyl, 4 cyl
engine .It had something with putting a wiff of
clean air into the exhaust, to dulute it and
trick the emissions test, into thinking that the
exhaust was cleaner.
RAB
03-13-2008 09:44:32
It is all about reciprocating mass and gas flow, plus a few other factors.
Two small valves will be better than the largest they can get in the space. Valves have to be opened against a spring (generally) and this takes power. One big valve closing needs strong springs and often double springs. Lighter valves are more easily controlled at higher engine speeds.
Gas flow can be improved with two smaller valves rather than one large one - more area and disribution into the combustion chamber can be improved.
Other things like cooling the valves (exhaust) and valve timing alterations as well as rate of lift can all have benefits.
Hope this helps.
Regards, RAB
Chad Franke
03-13-2008 09:21:55
My wife"s motorcycle is a 4 cylinder, and has 20 valves. 3 intake, 2 exhaust per cylinder. More area for the air to flow through when open with 3 smaller intake valves than if there was one bigger one.
coloken
03-13-2008 08:45:30
I think that engine has 8 spark plugs too. Like some air craft engines.
cj3b_jeep
03-13-2008 08:08:39
Some of them also had dual coil distributors
Nancy Howell
03-13-2008 08:08:23
I learned something reading this. Now I have a question. Cummins diesel 24 valves. Since this is a 6 cyl, is that two intake and two exhaust?
J Schwiebert
03-13-2008 13:36:29
 Re: 12 valves? in reply to Nancy Howell, 03-13-2008 08:08:23
Now if you get into a late Detroit Diesel 2 stoke with a 4 valve head the valves will all be exhaust valves. Intake is with ports in the cylinder. J.
trucker40
03-13-2008 10:30:32
Yes it is.Most big truck Cummins motors have 4 valves per cylinder.
circus
03-13-2008 07:53:56
I have the 12 valve 2400 engine. No gimick, it's got more power with the economy of a small engine. Two intake and one exhaust valve per cyl. Makes sense if you think about it. Pushing out is easier than sucking in. My woop a$$ minivan gets 27 mpg
Steven f/AZ
03-13-2008 07:28:11
The engines with 3-valves per cylinder usually have 2 intake valves and one exhaust valve.
Just like the newer Ford 4.6 and 5.4 have 3 valves per cylinder...
Link
