Tractor Talk Discussion Forum
Ford 8n PTO
codyh1066
03-12-2008 20:19:12
I have a ford 8n. I am having trouble with the pto shifting mechanism. It snaps on and off good but it wears the shift fork off really fast. just looking for some ideas.
soundguy
03-13-2008 06:50:48
 Re: Ford 8n PTO in reply to codyh1066, 03-12-2008 20:19:12
I'll that if it is twisted.. you may have a hard time getting it out.
remove the 4 bolts fromthe back bearing carrier..If it won't come out after medium persuasion.. then you may have to remov ethe inspection ports and cut the shaft for and aft of the pump.. drop the pump, and then pull the back of the shaft out of the couple, and then drive the slug out of the pump.. carefull.. you can damage the pump..
then ys got to wash out the sump and zip her back up with a new paper gasket and no gasket goop... then get a new shaft assy with bearing carrier.. usually about 100$ or so these days..
post back on the ford n board if you have problems..
soundguy
Tom Holland
03-13-2008 05:44:10
I think Bob's right. Ya get a bent or twisted shaft. Drain your fluid and unbolt the pto shaft and slide'er out and have a look. Let us know what ya find.
Bob
03-12-2008 20:31:01
Sounds to me like the shaft may be "twisted" in the spline area.
