Tractor Talk Discussion Forum
cam bearings for a Case 810B
Gary Steele
03-04-2008 18:38:52
The Physical size is 2.250 od
2.120 ID
4 bearings
My 1992 Michigan 77 book says a cam set SH-308S would be the correct set for the size of cam that is in the block
I have worked with parts houses accumalating all the liners pistons valves etc for a complete rebuid but the book keeps coming up with cam bearings that won,t fit. cam shaft dia.- 2.122
thanks to all gary [email protected]
george md
03-04-2008 20:12:53
 Re: cam bearings for a Case 810B in reply to Gary Steele, 03-04-2008 18:38:52
Gary, The early case engines had smaller dia cams, there are no more bearing sets to be had. I have the cure for your problem on the shelf as I have the same problem with the J series continental engines.
I'll send you an email thru yt .
george
