Tractor Talk Discussion Forum
Satoh S 650G
jhill52
03-04-2008 06:39:11
A friend has a Satoh 650G tractor. Does anyone know the hydraulic pressure on this tractor and is there any way to adjust it higher.
Thanks
Jerry
Walt davies
03-04-2008 07:23:20
 Re: Satoh S 650G in reply to jhill52, 03-04-2008 06:39:11
Unless you have the proper equipment and the proper pressure don't touch it have it done buy a dealer as the tiniest turn on the adjustment can jump from the proper pressure to twice that and cause a lot of major problems. This is not a job for an amateur or back yard mechanic as the pressure that can be reached can cause serious damage to the machine and the operator. Remember you are working with 2000 or better PSI and if not set right can reach 5000 PSI. Walt
jhill52
03-04-2008 10:23:04
 Re: Satoh S 650G in reply to Walt davies, 03-04-2008 07:23:20
Thanks Walt for the warning however I have the tools and knowledge to work on it I was just looking for some starting info.
Jerry
