Tractor Talk Discussion Forum
Tractor Year
Blugoat
03-03-2008 08:11:15
1.) I have a Ford 8N Tractor. The serial number on my tractor is 8N 451341.
Could someone tell me what year this tractor is? I was told it was a 1950.
2.) What is the mixture ratio, of Powdered Calcium Chloride to Water. That a person adds, to their tractor tires for additional weight.
Thank
Blugoat
BLW
03-04-2008 06:49:52
 Re: Tractor Year in reply to Blugoat, 03-03-2008 08:11:15
it is a 52 they started in 52 with ser. #442035
Blugoat
03-04-2008 04:19:10
Thanks everyone for all your help. I really appreciated it very much.
Blugoat
Bob
03-03-2008 08:20:16
 Re: Tractor Year in reply to Bruce Hopf, 03-03-2008 08:11:15
Blugoat said: (quoted from post at 11:11:15 03/03/08) 1.) I have a Ford 8N Tractor. The serial number on my tractor is 8N 451341.
Thank
Blugoat
1952. See chart linked below.
Link
Hydroinflation link:
(Note there's more than one page.)
Link
RodInNS
03-03-2008 14:04:13
I mix CaCl at 2 bags (88 #) to the drum (55 gal) if I don't want the stuff to freeze. Depending on where you're at you can probably get by with 1 bag per drum. 2 is overkill here for freeze protection, but the weight is good anyway... 1 bag is just marginal here. Probably 1 year in 5 will slush them up at that ratio.
Rod
higgins
03-03-2008 09:03:11
 Re: Tire salt mix in reply to Blugoat, 03-03-2008 08:11:15
A weight mix of 29.8% by weight gives optimum mixture for anti-freeze down to -60 F.
25% = 25 lb in 100 lb water [is also a 1:4 ratio]
This gives protection down to only about 40 below....If you go with more salt like 35 lb in 100 lb water; it will weigh more but the antifreeze protection is also less and probably like to -40 F. ALSO: 1 gallon of water is 8 lb so add 2 lb salt to each gal if the 25% is OK with you.
Sean Feeney 2
03-03-2008 08:27:07
I looked up that serial number on the site on the side, and it seems to be after 1952 model
old
03-03-2008 08:21:01
Look on the left under research&info then serial numbers then ford etc. I'll tell you how to do it but will not do it for you. Sort of the teach a man to fish thing
