Tractor Talk Discussion Forum
1989 ford f150
sparkplug
03-02-2008 13:28:18
it's a farm truck with a straight six EFI motor. when it's driven on the road, once and a while it will just die and won't start till it cools down for a while. whats the problem? fuel, electrical? help! i need it goin strong for spring so i can do some work with it.
Gary from Muleshoe
03-02-2008 13:52:36
 Re: 1989 ford f150 in reply to sparkplug, 03-02-2008 13:28:18
I had a 1986 F150 with the same motor that would do the exact same thing. It was the fuel pump. Mine was a manual fuel pump mounted on the side of the engine. I did not discover it until I had replace everything in the electronic ignition. The next time it does that pore water directly on the fuel pump and then see if it will start back up. Old trick my Dad taught me many years a go.
bradk
03-02-2008 13:47:47
More than likely the TFI module(ignition mod.)located on side of distributor.
Check to see if you lose spark when it acts up.Good indication of a bad TFI.~brad
Don-Wi
03-02-2008 13:41:37
My first bet would be the ignition modual. I think it's right inside the fender on the drivers side towards the cab. Maybe I'm thinking of another part that gave me troubles with my truck. Mine's an 88 F150 w/ the same 6 cyl. EFI controlled engine.
Donovan from Wisconsin
omahagreg
03-02-2008 13:41:10
I had a Ford car with 302 that did similar sporatic not running issues. Left it at the mechanic till it acted up, and he automatically replaced the crank sensor, even though it was a sensor on the distributor that tested as bad. Something to look at. Greg
sparkplug
03-02-2008 14:18:59
 Re: 1989 ford f150 in reply to omahagreg, 03-02-2008 13:41:10
wow thanks guys! that was quick!
