Tractor Talk Discussion Forum
getting my engine started
The man
03-01-2008 20:19:04
What is the best way for getting my "engine" Started and how do i satisfy it when i get him started? strategies acctepted, -- Dan
kyplowboy
03-02-2008 17:12:16
 Re: getting my engine started in reply to The man, 03-01-2008 20:19:04
Check your spam box, there should be plenty of info there.
Dave
John M
03-02-2008 15:03:14
Cialis?
Steve A W
03-02-2008 11:37:49
My brother say's "Flood em. they all start the same flooded! " He never had trouble with the old trucks on our Fire dept.
jose bagge
03-02-2008 05:34:08
sounds like what "the man" really needs to know is how to get "her" engine started, and how to satisfy "her" once he does. Hint: It starts by NOT being "THE man" but by being "A man"....
rrlund
03-02-2008 08:49:43
 Re: getting my engine started in reply to jose bagge, 03-02-2008 05:34:08
Oh boy! This is going off the deep end. My cousin used to say the ladies would say "who are you going to satisfy with that?" He'd say "myself".
Don L C
03-02-2008 01:38:56
Dan ---
It's best to say the make and model of your tractor when asking a question..... I'am a Farmall man..... ..they don't like a lot of choke..... set the brakes and lock 'em..... be sure it's out of gear.....set the throttle about 1/3...pull the choke 1/2 way out....turn the gas on under the tank...turn on the ignition...push the starter ...as soon as it starts push the choke in...if that doesent work, try differnt settings with the choke....they are all a little differnt..... .good luck...Don
steveormary
03-02-2008 14:15:34
 Re: getting my engine started in reply to Don L C, 03-02-2008 01:38:56
Right,Farmalls do not like alot of choke. I could start mine with no choke but had to use the choke to keep the running untill the warmed up. The farmalls were a 1939 M and a 300.
steveormary
B-maniac
03-01-2008 21:23:05
If you really were "The man" you wouldn't have to ask!
Bendee
03-01-2008 20:41:04
Your engine...If it's the day after the night before,a pleasing ale usually helps.A rather vague entry.
caleb in pa
03-01-2008 20:31:28
forgot to mention in my other posts- Ive seen the same id numbers before with different people but i thought each person was given a specific number?
caleb in pa
03-01-2008 20:25:53
What the heck this "dan" has the same id code as me. Thats not fair. Someone do something bout this. thanks- caleb
RobMD
03-01-2008 20:30:53
 Re: getting my engine started in reply to caleb in pa, 03-01-2008 20:25:53
before you get worried, just know that IP addresses do NOT indicate the identity of a person. No and's, if's, or but's.
Lanse
03-02-2008 05:35:41
 Re: getting my engine started in reply to RobMD, 03-01-2008 20:30:53
Nope, IPS are just internet connections and will ususally change every time you get on, and are sometimes the same by coincidence. Gets discussed alot here
caleb in pa
03-01-2008 20:32:41
Good Because i dont want to get blamed for making that rediculous stupid post! Thanks-caleb
