Tractor Talk Discussion Forum
How big of an Oliver rowcrop.....
Dalton Sogla
03-01-2008 12:16:11
would it take to pull a tandem 10 ft. disc? I would want the tractor to be pre 1958. I was thinking that an 88 or a Super 77 would do, but I know thats the lowest in power I'd want to go. Otherwise, I was thinking a Super 88. What do you guys think would be the best choice? Thanks
reply
03-01-2008 13:31:59
 Re: How big of an Oliver rowcrop..... in reply to Dalton Sogla, 03-01-2008 12:16:11
88 & super 77 have about the same HP. I'd choose the super 77. Super 77 is a little more nimble , and better on fuel. In a tractor of that era , the super 77 is a better all around tractor. The 88 may be a little heavier.
RobMD
03-01-2008 14:11:47
 Re: How big of an Oliver rowcrop..... in reply to reply, 03-01-2008 13:31:59
You need WEIGHT to pull a disk that wide. A 77 would sit there and spin. All the horsepower in the world will not amount to anything without weight.
I say the 88 with full ballast in the rear.
rrlund
03-01-2008 17:22:15
 Re: How big of an Oliver rowcrop..... in reply to RobMD, 03-01-2008 14:11:47
Aw come on guys,I don't think he's talking about an offset disc here. We used to pull an 8 foot with a 66.
rrlund
03-01-2008 12:28:08
The Super 77 would handle it. The Super 88 would too,and not that I'm saying there's anything wrong with the early Super 88s,they were a good tractor,but if you can find an "improved" Super 88,1957-58,then you'll have one heck of a tractor. One of Olivers best,hands down going away.
bradk
03-01-2008 12:26:45
Depends alot on your soil type.In MOST cases,an 88/Super 88 should handle it.
Might be a little too much for a Super 77.
RCP
03-01-2008 15:01:07
 Re: How big of an Oliver rowcrop..... in reply to bradk, 03-01-2008 12:26:45
We farmed with 77 and 88s, and you might be able to pull the disk with a S-77, but if you add a drag or set of spring tooth harrows, you will want the S-88. BTDT
steveormary
03-01-2008 17:42:01
 Re: How big of an Oliver rowcrop..... in reply to RCP, 03-01-2008 15:01:07
This might help.We pulled an 11ft.tandem with a super M. Mostly in 2nd gear.
steveormary
Larry NE IL
03-01-2008 19:57:55
 Re: How big of an Oliver rowcrop..... in reply to steveormary, 03-01-2008 17:42:01
I always pulled a 12 footer with my 77. Had super pistons in it, but handled it fine.
