Tractor Talk Discussion Forum
Weights and Rephrasein' the Question
Wild Bill Caldw
02-28-2008 04:32:47
Thanks For givein' Me the weight of the weights I just bought..... Now I need to know or I'm am askin' for advice on how much weight to put on the front end , How much to put on the rear tires. My tractor is a Farmall 504 Diesel...I have suitcase weights (6 @ 100lbs ) for the front, Half circles for the rear (475lbs for each side ) This will be used in loamy soil, Pullin' a cut off chisel plow, Three bottom plow, 7ft disc. I'm lookin' for a 7ft bushog.
Thank Yaw'll
Wild Bill
Bruce Hopf
02-28-2008 07:24:27
 Re: Weights and Rephrasein' the Question in reply to Wild Bill Caldwell, 02-28-2008 04:32:47
I have wheel weights on my Fordson Supper Major, and some 3 point hitch implements are heavier than others.If you look an the sides of your tires, Your tires have a weight rating on them. Add the wheel weights, hook up your heaviest 3 poimt hitch implement. With it in the air. gradully start adding weight to the front of your tractor. rember, don,t exseed your max tire rating. Hope this helps.
rrlund
02-28-2008 06:59:08
Funny,I was just reading this morning about something that happened back in the early 50s. Seems the boys were tired of Dads tractor coming up in the front,so they strapped a bunch of wheel weights to the cultivator brackets in front. Tore the bull gear out in a matter of hours. Replaced it and the next one lasted about 4 hours too. They took the weight off then. Had'er so heavy she wouldn't slip.
IaGary
02-28-2008 04:46:52
I'd maybe start with 300 on each side. Then add the other 150 lbs if needed.
See how much spinning you do and go from there.
Unless the the chisel and the 3 bottom plow are 3pt. mounted you probably don't need any front weights.
We never ran any front weights on our 560 to pull a 4 bottom trailer plow.
With a 5 bottom 3pt mounted on a 856 we had to run a full rack of weights.
The less weight you carry around the more fuel efficient the tractor will be. As long as the tires aren't spinning all over the place.
Gary
