Tractor Talk Discussion Forum
Hay -OLD tractor back fired
Larry59
02-24-2008 18:40:32
Started tractor up and it run pretty good. Adjusted the carb both on power and idil. Then turned if off and on a few times and it just fired up good. ... Left it alone for about 1/2 hour and went back out.. Kaboom out the exhaust and would not hit a lick. Any ideals?
Larry59
02-25-2008 03:46:41
 Got the phone call at 5 am this morning. in reply to Larry59, 02-24-2008 18:40:32
Will check on this as soon as I can. Having to go to Arkansas again. Father inlaw did not make it this morning. Got call at 5 am and will wait to see when service for him is for heading out. Also heading for doc my self this day.
Joe (Wa)
02-24-2008 22:10:46
 Re: Hay -OLD tractor back fired in reply to Larry59, 02-24-2008 18:40:32
Well, you just worked on the carb. If you haven't already done so, back off the intake pipe away from the carb and try starting it.
These carbs are prone to flooding after being apart, fills the intake pipe with gas.
Joe
old
02-24-2008 20:59:12
Well since we talked on the phone you know what I think. Points and or rotor and cap.
IH2444
02-24-2008 19:00:08
Got gas in it ?
Larry59
02-24-2008 18:44:18
Ment idle on other form.. dang fingers.. *S
