Tractor Talk Discussion Forum
Problems on fuel gage??
Larry59
02-24-2008 17:40:21
Today I installed my new dash. But found on the fuel gage. That I had 12 Volt power going to it. But no power coming out the other side that runs to the new float sending unit. Any susjestiong????
Walt Davies
02-25-2008 08:42:02
 Re: Problems on fuel gage?? in reply to Larry59, 02-24-2008 17:40:21
Larry take the wire loose from the sending unit and ground it to a good ground on the frame. The gauge should either go to the low side mark or the high side mark if it doesn't move then the gauge is bad if it does then the sending unit is bad.
Walt
old
02-24-2008 18:17:39
Larry, how you testing for power?? A test light or meter?? Most gauges work one of 2 way. empty tank high resistance so that will lower the voltage of empty high voltage and then higher volts. Hard to test with out a meter.
Larry59
02-24-2008 18:35:54
 Re: Problems on fuel gage?? in reply to old, 02-24-2008 18:17:39
Using a 12 volt tester is all I have. Got no kind of light on it, on the sender side.
