Tractor Talk Discussion Forum
Steel Prices
Larry D.
02-16-2008 19:29:24
I haven't looked Lately, But STEEL prices must have went Out the Roof, As it Seems Every Drifter that passes through Stops at My Place and asked about Scrap Steel/Metal, To Buy or give away??Just venting! Larry KF4LKU
Dairy Farmer in WI
02-17-2008 16:35:38
 Re: Steel Prices in reply to Larry D., 02-16-2008 19:29:24
yeah a few weeks ago i had a guy stop by my farm cuz i got an old car sittin' out back and some old worthless machinery. they way i understood it was that i would get 1/3 back of what they got! i told them flat out that if i wanted to get rid of them i would do it myself, and pointed at my gooseneck! told them i wasn't interested and the guy was realy persistant so basically (indirectly) i told him to f-off that that i wuold haul it in myself or cut them into 3ft. never saw that guy again!
DF in WI
canadian northerner
02-17-2008 10:58:08
Up here in canada the cost of scrap has sky rocketed. Dealers say its China rebuilding into the modern world.Several bad guys have been killed trying to strip live old copper wire from hydro lines.Time to clean up the enviroment of those old autos.Just hope they leave our tractors alone.
Roy Suomi
02-17-2008 05:17:06
I heard somewhere that if you burn the insulation off copper wiring that it falls into a lower grade of copper and not worth as much..Any truth to it??...How about sitting around some evening with a couple of cold brewskies and a utility knife..Sure beats re-runs on TV...Unless it's Catherine Willows of CSI or Abby of NCIS....
Glenn F.
02-17-2008 06:42:24
 Re: Steel Prices in reply to Roy Suomi, 02-17-2008 05:17:06
ANYTHING beats watching television!
Glenn F.
MF Poor
02-17-2008 05:56:34
Most of the local scrap buyers around here will buy insulated wire "as is". They have machines to strip it. They'll dock you considerably for bringing in burnt wire. Better money for selling with insulation left on. State, county and local ordinance's against burning plastic anyway.
old
02-16-2008 20:40:24
Yep getting to the point a Farmall H is almost worth more as scrap then it is in good running shape which is sad, very sad. Last I checked scrap was going for around $250 a ton which means a Farmall H is worth at least $250 just as scrap if not more
Name Withheld
02-16-2008 20:36:57
If you catch one, call out to him, have him walk toward you. When he giet about 20-30 feet shoot him. Shoot him good. He should not have come at you in such a threatening manner. No real explanation for it, he must have panicked when you caught him stealing. Just remember, you felt your life being threatened. One more out of the gene pool. Give one statment to police, never discuss it with anyone, ever. If police want to "go over" your statement, lawyer up and keep your mouth shut. This is the ONLY way to stop this kind of crime.
oldmax
02-16-2008 20:18:11
I friend of mine had two old trucks out behind his barn he only uses a few times a year . to get in hay & fire wood and such . went to start one the other day was dead, started checking , some one had cut all the wireing out of both trucks . What are we going to have to do to stop this . They went on my farm two years ago cut down 400' service cable "was live" to my camp site & even cut wiring out of picknick shead .
mike a.
02-16-2008 20:06:25
any junk car brings $200 at our salvage yard w/tires,gas tank,glass. Not so picky anymore
jose bagge
02-16-2008 20:06:05
around here, seems like the only interest is in the "get rich quick" metals- aluminum, copper and lead. I have several auto repair shops, and can't hardly remove a bent aluminum wheel without someone at the door ready to pick it up...same with buckets of used wheel weights and battery cores. but tote off the brake drums and rotors? not on your life!
County condemned 6 houses last year to build a resevoir- everyone of them got broke into and stripped of copper plumbing and wiring. I'm reading that these jokers are being found electrocuted now, as they're trying to pull live wires and getting zapped in the process.
504-2
02-16-2008 19:52:04
The local Sheriff has two idiots in the can now the didn`t think anybody would mind if they helped them selves to the cooper in a local house that was empty.
RayP(MI)
02-17-2008 10:57:12
 Re: Steel Prices in reply to 504-2, 02-16-2008 19:52:04
We had a couple of guys picked up in the wee hours recently here with a truck load of stolen aluminum and wiring taken right off a center pivot irrigation system in a farmer's field.
Sam from WA
02-16-2008 22:29:46
now, i've got a question. this is legit, not illegal. we just tore down an old barn at my parents old place and pulled all the wiring so we could burn the wood the barn was built out of (it was full of powder post beetles). legally, we weren't even supposed to burn the wood, which is stupid, but burning it sure as heck beats haulin the whole 90x80 100 year old barn to the dump unburned. What is an easy way to strip the insulation off the old wiring so we can take it in for scrap copper? again, this is not an illegal activity, perfectly legitimate.
Larry D.
02-17-2008 06:48:18
 Re: Steel Prices in reply to Sam from WA, 02-16-2008 22:29:46
Hi SAM : I Too have an Old house like, That I will eventually have to do something , Only way I know is Pull all You can Out easily, and then take the Walls down (As much as need be) where You can see the Wiring entering/Leaving??Larry KF4LKU
sjh
02-17-2008 05:54:08
Best way is with a sharp knife. Burning it can make it brittle(hard to pick up) or melt it. Some yards pay less for it burnt as well.
awhtx
02-17-2008 01:43:13
When you burn the barn throw the wiring on the fire and it will burn the insulation off. Easiest way I know to do it.
