Tractor Talk Discussion Forum
Hydrostatic transmission question
gun guru
02-16-2008 01:40:17
If you have a tractor that is hydrostatic drive what do you do if the tractor stalls and you cant get it started? Is there a lever on the drive train to disengage the wheels so that you could tow it into a garage to work on it? Even a car with an automatic transmission has a neutral to shift into. Give me some info here guys.
Goose
02-16-2008 06:47:51
 Re: Hydrostatic transmission question in reply to gun guru, 02-16-2008 01:40:17
On the old Ford Select-O-Speeds, there was a way to disconnect the differential so it would free wheel for towing.
RayP(MI)
02-16-2008 05:31:34
Mine has a bypass valve which allows the transmission to operate in a neutral situation.
FredWi
02-16-2008 01:47:02
It's the same way on my Kubota. It has
three ranges and you just put it in neutral.
