Tractor Talk Discussion Forum
CASE S TRACTOR
canadian northe
02-15-2008 16:27:55
CAN YOU CHANGE A 6 VLT CASE S TO A 12 VOLT SYSTEM IF YES HOW DO YOU DO IT?
old
02-15-2008 17:09:41
 Re: CASE S TRACTOR in reply to canadian northerner, 02-15-2008 16:27:55
Yes it can be done. You need to have the generator rebuilt to put out 12 volts or replace it with an alternator. The replace the coil with a 12 volt one or add a ballast resister. And then wire every thing up the correct way
canadian northerner
02-17-2008 11:15:20
 Re: CASE S TRACTOR in reply to old, 02-15-2008 17:09:41
Thanks for the info but, there is no coil on the case s , there is a generator and a magneto. Now what do I do?
old
02-17-2008 12:52:13
 Re: CASE S TRACTOR in reply to canadian northerner, 02-17-2008 11:15:20
Well then since you have a mag instead of distributor it makes it easier but harder if that makes since. You can have the generator rebuilt or do the alternator thing but then you also have to add a switch to turn things on and off as far as the generator or alternator. I did one not long ago on a Farmall B and hooked up a pressure switch so when the engine oil pressure came up to over 4 psi it would switch on the alternator and when the engine was shut down it would then switch it off again
