Tractor Talk Discussion Forum
farmall exhaust plug??
jason eddleston
02-14-2008 17:22:39
hi,i have a farmall a and the old exhaust had a square plug on it right above the carb,the new one i have dont,what is it?what does it do?thank you..
Hayshaker
02-15-2008 06:18:10
 Re: farmall exhaust plug?? in reply to jason eddleston, 02-14-2008 17:22:39
I can remember using the TO20 Fergie to run the milking machines when the power went out. Dad had replaced the plug with a petcock which you could attach the hose.
Wayne in MN
02-14-2008 20:17:14
It was a vacuum source so the dairy farmer could use the vacuum operated milking machine when the electricity went out.
Much better than milking by hand. BTDT
Jaden
02-14-2008 20:05:24
Perhaps intended for help in difficult starting?
onefarmer
02-14-2008 19:05:58
That plug is on the intake side, but I've never heard of anything it might have been intended for. Maybe as a emergency way of powering the old vacuum run milkers?
The old lifts on the A's and B's were exhaust driven.
IH2444
02-14-2008 17:56:24
I can't recall if the old lift mechanism was exhaust or vacuum driven ?
IH2444
02-14-2008 17:41:46
Might have been a hookup point for the old exhaust driven lift mechanism ?
jason eddleston
02-14-2008 17:45:31
 Re: farmall exhaust plug?? in reply to IH2444, 02-14-2008 17:41:46
i had the tractor running and then i pulled that plug,it died.
IH2444
02-14-2008 17:55:04
 Re: farmall exhaust plug?? in reply to jason eddleston, 02-14-2008 17:45:31
Sounds like it is on the intake side then.
