Tractor Talk Discussion Forum
s-o-s pto shaft
briley
02-14-2008 11:47:25
i have a 1964 ford 2000 tractor with a select-o-speed transmission. when having the side plate for the disengagemnent lever off i noticed what looked to be a bearing placed around the pto shaft that floated along the lenght of the shaft. the bearing was not attached to anything. the pto shaft was attached to the output shaft of the transmission and the rear pto shaft bearing with little or no play in the shaft. any help on the purpose of this bearing?
Larry NCKS
02-15-2008 04:08:30
 Re: s-o-s pto shaft in reply to Allan In NE, 02-14-2008 11:47:25
Yup Ford is the board to post this on, but fortunately Ultradog picked it up and brought it to us.
Here's my responseLink
If #2 is correct, you should have fluid transfer from your transmission to your hydraulic reservoir.
NWMO 901 SOS
02-14-2008 20:40:09
 Re: s-o-s pto shaft in reply to briley, 02-14-2008 11:47:25
briley,
Please find attached explaination posted on the Ford board.
HTH
Chris
Larry59
02-14-2008 20:35:21
If you don't get any help .. might be cause form is slow tonight. Real slow ! You might try posting the same over under the Fords. Can't hurt.
