Tractor Talk Discussion Forum
Magneto AND/OR Timing problem?
loveshisallis
02-13-2008 13:07:40
I got a funny problem that is not making sense to me. I put in new points and condenser into my FM J magneto, and throws spark 3/8 inch on all wires as you turn the impulse.
Problem IS, even after reading MULTIPLE POSTINGS of how to time it to a Allis Model B, it just will not go. I know that it works as the engine runs good whe hooked up to the stock distributor.
Sooooo , any body got some good ideas as to what is what here? I would like to have it running by springtime!!!!!
dobber
02-13-2008 22:12:34
 Re: Magneto AND/OR Timing problem? in reply to loveshisallis, 02-13-2008 13:07:40
Well just look at one more...
dieselpaul
02-13-2008 15:52:04
are you correct on mag internal gear timing ?
loveshisallis
02-13-2008 16:15:42
 Re: Magneto AND/OR Timing problem? in reply to dieselpaul, 02-13-2008 15:52:04
On the internal timing, that is the thing.
there IS a "dot" on the steel pinion gear. BUT when I use that as a index, no fire. ALSO, I am told that this is not the mark. that it should be a chamfer or a red dot.
SOOOOO OOO, obviously this a conflict.
Wayne in MN
02-13-2008 15:15:54
Are you using the wrong switch? A mag has to have an open connection when running and grounded connection to stop. Distributor ignition is the opposite; it needs battery power to run and is disconnected to shut down.
With the mag installed, leave the primary wire disconnected while attempting to start the engine; if it runs, you can just touch a screwdriver from ground to the terminal to shut down.
Keith-OR
02-13-2008 14:45:51
did you ever go to the following website I posted for you the last time. If you read and follow the instructions you should not have any problems on timiong your FMJ mag.HTH
Keith & Shawn
loveshisallis
02-13-2008 16:16:56
 Re: Magneto AND/OR Timing problem? in reply to Keith-OR, 02-13-2008 14:45:51
Yep. Went there . Read the other post I jsut added, about the "index" marks.
Dick L
02-13-2008 13:19:14
Send me an email I opened it above.
