Tractor Talk Discussion Forum
Kubota snowblower shear pins
Ross Campbell
02-12-2008 17:12:17
My father-in-law has a 21 HP Kubota tractor and uses a 4 Ft snowblower. I don't know the brand. About every 20 minutes the shear pin on the blower fan gets sheared off. The shear pin on the auger is OK. My father-in-law has a whole box of bolts from a hardware dealer who claims they are very high strength. The fan is not caught up on anything. Do you think the fan simply can't keep up with the auger of can the shape of the shute make any difference? Thanks in advance for your comments
Jim in Ma.
02-12-2008 18:59:41
 Re: Kubota snowblower shear pins in reply to Ross Campbell, 02-12-2008 17:12:17
Two things come to mind. I had that problem and found that I was using standard size - after I changed to metric I had less problem. Also = a blower will work better when running at high speed, when I run mine slow it does shear pins. Good luck. Jim
