Tractor Talk Discussion Forum
Throttle Friction Washer Question
robnmiss06
02-10-2008 15:02:53
Hello,
I have a problem with my throttle lever not staying in full throttle position. I disassembled and put in a new cork friction washer and it will not stay in the full position. I pushed the tension spring over to full tension position against the cork washer and the throttle will still not stay full throttle. Any help would be greatly appreciated.
IH2444
02-10-2008 19:45:15
 Re: Throttle Friction Washer Question in reply to robnmiss06, 02-10-2008 15:02:53
My IH had a spring that was supposed to push on the friction washer, but the mechanism had siezed up and it was not pushing on the friction washer.
bradk
02-10-2008 15:57:30
Golly gee robnmiss06:
May be helpful to reveal what tractor(if any) we're talkin' 'bout!
Stop
02-10-2008 16:46:16
 Re: Throttle Friction Washer Question in reply to bradk, 02-10-2008 15:57:30
Your reply was insensitive and not helpful. You need to be more courteous.
bradk
02-10-2008 17:47:32
 Re: Throttle Friction Washer Question in reply to Stop, 02-10-2008 16:46:16
Take a pill and think about it. A make/model would certainly be helpful,don't you think?
Sorry I hurt your feelbads.Hope ya don't need a hug er anything.
Oh and next time please post a name or real handle to go w/your insensitivity traffic stops.
Well, well
02-10-2008 18:05:55
 Re: Throttle Friction Washer Question in reply to bradk, 02-10-2008 17:47:32
I think you could use some sensitivity training.
Cheney's Kuzin
02-10-2008 15:24:05
I had the same problem on an old Ford. Someone had put a return spring on the throttle linkage. There should be no return spring on the throttle linkage so when I took it off the problem was cured.
