Tractor Talk Discussion Forum
ouch!!!
glennster
02-07-2008 11:33:52
just went to change a tire on an f-350, got the tire off, started to roll it, dang single edge razor blade was stuck in the tire, slashed my 3rd finger wide open. some band aids and duct tape, back in action. never had that one before!!!!
Mark from WI
02-08-2008 20:29:38
 Re: ouch!!! in reply to glennster, 02-07-2008 11:33:52
I fixed a tire at the repair shop I used to work at that had a muffler clamp stuck in it. Customer didn"t want to buy a new tire.
Aaron Ford
02-08-2008 11:53:08
Wow! I have been torn up by tire cords before, but never anything protruding from the tire. That had to be a surprise. BTW, where did your taillight go?
Aaron
glennster
02-08-2008 12:11:28
 Re: ouch!!! in reply to Aaron Ford, 02-08-2008 11:53:08
aaron, tail lamps are taken out, we are repairing both bedsides, had a camper top on it, it blew apart on impact, also knocked the rear slider window to bits, dented the roof good, also rt door and cab corner., that 7.3 turbo is one heavy motor!!! add the 4wd with the transfer case, holy cow. weird thing is the rear differential is a 3:55 gear, front diff is a 3:54 gear. done that way due to the diesel motor weight on the front tires. who"d a thunk!!!
Dachshund
02-08-2008 10:21:32
I was following behind a "Lawn Service" guy one time. I saw something small fall off his trailer and swerved, but couldn't miss it. It turned out to be one of thes small rakes that people use in their flower beds. All tree fingers were BURIED in my front tire. The guy saw me in his mirror and actually stopped. He helped me put the spare on and followed me to the store to get a new tire.
James Howell
02-08-2008 09:29:01
Bush-hogging with my Ford in a wooded area and had a flat on the front right tire.
Upon inspection of flat tire fount a 3 point deere antler.
James Howell
02-08-2008 11:29:49
 Re: ouch!!! in reply to James Howell, 02-08-2008 09:29:01
Sorry for using the wrong word.
Should have been deer instead of deere.
greygoat
02-08-2008 08:34:23
Had a flat, found a KEY in the tire
Kent in KC
02-08-2008 07:51:37
A freind of mine had a flat once, got it fixed, guy said he found what made the hole - a pair of needle nose pliers, went all the way inside the tire.
Larryin IN
02-08-2008 07:37:18
Better have your Tetanus records checked.
Genos
02-07-2008 20:52:55
Back In the 50"s My Dad Worked On the Railroad & There Was A Gas Station Near Where Parked His Car for the Day, So He Had Them Put 2 New Tires On His Car, These Tires Were Sitting Inside Near Where The Candy, Pop Cigeretts And Razor Blades
Were Kept. On His Way home He Had a Flat And Took Tire Back Next Day & A Package Of Razor Blades Were In Tire Between Tire & Tube, They Were On a Display Above The Tires In The Station. Don"t Know Why They Missed Them?
TomTex
02-08-2008 12:05:21
 Re: ouch!!! in reply to Genos, 02-07-2008 20:52:55
You must like capital letters.
Sam#3
02-07-2008 20:24:34
It can happen. Once picked up a utility knife blade in Dad's pickup off a city street.
Dairy Farmer in WI
02-07-2008 19:44:02
that's gotta hurt bad. was it a back tire by chance?
DF in WI
ken in texas
02-07-2008 17:37:43
front tire stood it up,back tire caught it.(assuming back tire).
Ranky-2
02-07-2008 17:29:50
This is a stupid post. dont believe it.
glennster
02-08-2008 06:14:59
 well a picture is worth a thousand words in reply to Ranky-2, 02-07-2008 17:29:50
here is the truck, and the razor blade and my finger. any other ?????'s. blade was stuck sideways on the back side of the left front tire. sticking out on the inside of the tire. putting a front axle asem in this one, went off the road and tore the front 4wd all to heck.
third party image
third party image i had cuts in the past from torn cords, but never had a tire with a blade stuck in it. just wanted to post it so it wouldnt happen to somebody else.
Dairy Farmer in WI
02-07-2008 19:42:54
 Re: ouch!!! in reply to Ranky-2, 02-07-2008 17:29:50
well if it's a stupid post then why are you looking at it and commenting? keep yer negitive comments to yerself!
DF in WI
Janicholson
02-07-2008 17:39:06
There is a far greater likelihood of a razor blade in the tire than finding value in your comment. JimN
hay
02-07-2008 12:14:32
heck, ya don"t need to change the tire. just rotate it to the side that is not flat. at least that what some folks believe. razor cut hurt like heck. get some aloe vera and squeeze the juice on it. it will heal faster and with much less pain and swelling.
Joe in MN.
02-07-2008 11:46:34
I smashing my finger once when loading the wood stove --- I soaked it in Vinegar for an hour --- it never got infected -- and healed right up --- that information comes from the Doctors back in the Old ages ... take that advise and use it ....
Don-Wi
02-07-2008 11:46:19
Atleast you know why it was flat now right? MAkes ya wonder how that razer blade got stood up enough where it would actually go into the tire....
Donovan from Wisconsin
