Tractor Talk Discussion Forum
O.T. G.M.C. pickup power window
john-mi
02-04-2008 10:34:06
Has anyone changed the window motor on a 2000 GMC siera pickup. Also should you change just the motor or the motor and regulator. How bad of a job is this? Thanks for the help.
John - OH
02-04-2008 18:56:33
 Re: O.T. G.M.C. pickup power window in reply to john-mi, 02-04-2008 10:34:06
check the cables on the regulator, they rust and frey causing a groaning sound. Not bad to fix, half dozen bolts and about an hour tops. I got an 01 and have done both sides. John
jim wise
02-04-2008 17:34:59
look, the advice on the regulator is right. if it is a cable drive regulator buy a new one and put it in. they break all the time. its a stranded cable running over plastic guides and the guides break. at this point buy new. my computer show aftermarket but id have to call gm price 175.00 jim
skip33652
02-04-2008 15:36:18
the motor and track are all in one unit with cables that criss cross . basically an unservicable unit .not a bad job to do at all once you get door panel unsnapped.Paul
dave guest
02-04-2008 15:04:48
Changed a couple Fords. All that really was wrong was excess grease got into the motor brushes. Summertime preferred.
ArleninOr
02-04-2008 11:50:54
Go with what Bo said. Take door panel off and see if the gears and linkage are dry. Might try lubing up before buying that window motor.Not to hard to change as long as you can stand on your head and have small hands.
1936
02-04-2008 10:41:29
The good new is the last GM power window motor I had installed are now after market saved about half.
Allan In NE
02-04-2008 10:37:25
FWIW,
Check the wiring loom coming thru the hinge area of the door pillar. They have a real nasty habit breakin' wires and it's usually always that most used driver's door.
Allan
john-mi
02-04-2008 10:59:10
 Re: O.T. G.M.C. pickup power window in reply to Allan In NE, 02-04-2008 10:37:25
Thanks Allan, but the motor when it works groans like a bad bearing or something. Dont know if its the motor or regulator.
bo
02-04-2008 11:28:10
 Re: O.T. G.M.C. pickup power window in reply to john-mi, 02-04-2008 10:59:10
Might not be the motor...the linkages for the window may be binding. Often a moaning motor means that it"s trying to run but it doesn"t have the power to get past a resistance, like a binding linkage.
