Tractor Talk Discussion Forum
Kubota Front Final Drive
ChrisA
02-04-2008 07:02:48
Broke the rt side final drive bracket where the steering arm attaches, moving snow. $500 part in my area. Any one know where I might find a used final drive housing or how easy this cast iron piece is to weld?
Any help appreciated, thanks. Chris
David Snipes
02-04-2008 10:13:29
 Re: Kubota Front Final Drive in reply to ChrisA, 02-04-2008 07:02:48
I would try to repair it before buying new. I would also add some extra weld material on the right side and fill in the 90 degree area.
Mike M
02-04-2008 08:57:11
I'd try fixing it. You may not even have to take it all apart ? Vee it out and weld it. Might be a real good spot to try the welding rod F-I-T (over at the JD board mainly)recommends called Muggy Welding Rod.
JD9295
02-04-2008 08:46:29
You could weld it or take it to a machine shop but I dont think it will hold from looking at the pics
ChrisA
02-04-2008 08:32:26
third party image
L2950. Here is a pic of the problem.
Eldon (WA)
02-05-2008 07:20:25
 Re: Kubota Front Final Drive in reply to ChrisA, 02-04-2008 08:32:26
Chris I think this needs to go in the "stuck and troubled" area.....it's stuck and you're troubled :-(
comfortking
02-04-2008 08:48:43
Find a good welding shop and have them braze it. I have an 1145 deere that we broke and was welded twice but did not hold, last time took to another shop that knows metal and was brazed. Has lasted four years The last repair was made by a 92 year old man that works five ten hour days, he has been a welder for 75 plus years.
Ken Macfarlane
02-04-2008 08:19:12
Model? kubota make 5 - 120 hp tractors
