Tractor Talk Discussion Forum
5000 ford remote valves
npuller
02-02-2008 18:01:41
third party image
Hi every one I have a 67 5000 ford with the factory singel remote hose that works with the aux valve pulled out on the side of the lift cover and uses the 3pt lever to operate .Can I install the valve in the pic and still use the singel hose to. I only need 3 hoses. The singel hose I have now will raise and lower the cutter bar on a hydswing mower.I need the other two to swing it.I put this on the ford bord but did not word it right.thanks. Ross D Booher
Leroy
02-03-2008 10:53:42
 Re: 5000 ford remote valves in reply to npuller, 02-02-2008 18:01:41
The setup you have now is only for use with a semi-mounted plow with the cylinder to raise the back end with just one lever, not intended for any other use. get the correct double handle valve and use as is supposed to be.
npuller
02-03-2008 09:18:34
Thanks for the inf you all.
Fordfarmer
02-03-2008 07:06:18
Not positive, but I don't think your idea will work. I think teh single hose you have now will have to come off the add the valve. If I remember right, it's tapped out of a plate just under the front of the seat, which is where the valve fits. If you can find a two-spool valve, you'll be good to go. They show up on ebay from time to time, or are available new from NH or this site.
ben brown
02-02-2008 21:01:04
i say yes. the remote your talking about bolts on top of the top cover 3pt hitch assy. it wont have any effect on the 3 pt. should be a plate you remove rt front of top cover. if the valve is made to be used on ford tractors should work fine
IH2444
02-03-2008 01:14:55
 Re: 5000 ford remote valves in reply to ben brown, 02-02-2008 21:01:04
My friend has a 5000 and you will have to have the proper ford remote valve. If anyone knows any different please let me know.
