Tractor Talk Discussion Forum
Water leaking from manifold bolts
ROYBOY
02-01-2008 08:09:57
A friend installed heli-coils for the manifold bolts and now water is leaking from the threads. Van you use a stop leak in the JD anti-siphon systems? What would you recommend fixing this? Tks in advance.
glennster
02-01-2008 10:49:00
 Re: Water leaking from manifold bolts in reply to ROYBOY, 02-01-2008 08:09:57
lock-tite makes a product called wick and lock. it is a thread sealer-locking compound you put on after the fastener is installed. it will creep in along the threads and seal.
fixerupper
02-01-2008 10:35:39
The manifold stud holes in the 2 cyls are blind holes so coolant shouldn't get to the stud. However, if a stud is twisted off and then drilled out the drill bit could have easily gone through the bottom of the hole and into the water jacket.
Gasket sealers do work sometimes; sometimes not. Usually it seals itself up over time, but in the meantime that little drip of anti-freeze is going to be running down the side of the head and streaking the paint. Jim
old
02-01-2008 09:13:53
Its not an anti-siphon system but a thermo-siphon system. Big question is does it leak past the heli-coil or the bolt or both. If its both then you have a problem that will be hard to fix unless you can pull the heli-coil back out. My self I have had good luck using silicone gasket sealer to stop leaks on stud bolts but as I said if its the coil treads that leak then you need to pull them and seal those treads also
Bob
02-01-2008 08:33:05
Are you using bolts or studs?
I would use studs, and seal them in place with a quality pipe dope. If that doesn't work, I would drain the coolant, thoroughly clean and dry the threads/inserts, and slather a litle epoxy (JB Weld, or your favorite kind) down in the threads, and on the stud threads, and then install the studs.
jonjon
02-01-2008 08:16:36
Does it not have a gasket to stop the water from getting to the bolts
