Tractor Talk Discussion Forum
Best tractor
Dalton Sogla
01-30-2008 19:23:18
What would be the best early 50's tractor to buy with dual hydraulics that has around 40 HP? I was thinking an Oliver 88. What do you guys think? I'm sure everyone will have their own favorite. Thanks
Hoss in Maine
02-01-2008 18:32:18
 Re: Best tractor in reply to Dalton Sogla, 01-30-2008 19:23:18
730-830 Case=gas or deisel Later Hoss
The Dukester
02-01-2008 08:45:27
I'd look for the best Farmall 450 gas I could find...it's a tractor with just about everything you need and a good looker that you can find any part for....and they're cheap compared to SMTA's.
I don't know about other brands except John Deere and they're not cheap for good ones.
buickanddeere
01-31-2008 15:22:25
Why a 50 year old tractor? There are 20 year old used tractors with more features, fewer hours, less abuse for similar money.
bradk
02-01-2008 17:22:14
 Re: Best tractor in reply to buickanddeere, 01-31-2008 15:22:25
B&D, That Oliver will be here for another 50 years.Doubt too many newer tractors will even see 50 years total.
Bill(Wis)
02-01-2008 07:56:43
I'm for the Essex Tri-Directional. Remember those?
ejr-IA
01-31-2008 12:53:05
You won't go wrong on a good 88.But if you can find a supper 77 or 88 with the better hydraulics and brakes.
135 Fan
01-31-2008 12:02:59
What do you need the dual hydraulics for? In the 40 HP class, a tractor with a 3 pt. hitch is most desirable and gives you a more versatile machine with lots of implements available. If the hydraulics are for a loader, many tractors can have a front pump installed, or a PTO pump. You could get a newer than a 50's tractor as well. Are you thinking of buying or just asking a question? Dave
JNP
01-31-2008 09:14:49
Oliver 88 or S77 would be the best if you aren"t going to use a 3pt a lot. Aftermarket 3pts for these tractors are clumsy and make implements hard to hook up. A Ford would be better for this type of use but the Oliver would be better than the Ford in everything else.
Walt Davies
01-31-2008 08:54:43
The one your neighbor has its always starts cost nothing to run and looks great from across the road.
Walt
Dave Sherburne NY
01-31-2008 07:15:14
The 88 not only has dual hydraulics, it also has
independent PTO that you won't find anywhere except
on a Cockshutt but the Cockshutt won't have the
dual hydraulics
Mike M
01-31-2008 09:49:04
 Re: Best tractor in reply to Dave Sherburne NY, 01-31-2008 07:15:14
I'm pretty sure the neighbor had a Farmall SMTA with live pto. And John Deere had models going back to 1949 with it.
Dave Sherburne NY
01-31-2008 14:24:24
 Re: Best tractor in reply to Mike M, 01-31-2008 09:49:04
Independent PTO is completely independent of the foot clutch, can be engaged or disengaged without
touching the foot clutch and continues to run even
when the foot clutch is depressed unless it is
disengaged by its own lever. Any other type is not INDEPENDENT PTO
Massey Ferguson used a two stage foot clutch which
partially depressed disengaged the transmission
but not the PTO. The foot clutch had to be pushed down to engaged or disengage the PTO lever. The Ford 8N had to be completely depressed
to engage or disengage the PTO Engaged with the
clutch up and engine running turned the PTO shaft
To stop it from turning the clutch had to be
completely depressed. That said , I think the early Super MTA
tractors didn't have independent PTO but the later ones did. I don't know of any letter series
John Deere that had IPTO BUT I could be wrong.
buickanddeere
01-31-2008 15:26:40
 live or independent who cares? Re: Best tractor in reply to Dave Sherburne NY, 01-31-2008 14:24:24
Independent or not it's live pto. Who cares? In fact a two stage foot clutch will shut down everything in a problem situation faster than operating two separate controls. Mother Deere released live pto in 1949,1952 & 1957 depending on the models.
greygoat
01-31-2008 06:06:22
Koiti, or Hinomoto ? Are those the ones that come
with a free bag of rice?
bradk
01-31-2008 05:38:16
You won't go wrong with the Oliver.Great all-around reliable tractor.Easy to work on,easy to operate,independent PTO,good hydraulics.
dej(jed)
01-31-2008 05:37:14
A Farmall M is your best buy for the money. You can do almost anything you want with it safely.
I like the sound of the 88, but they aren't operator friendly. An old M will pull the tires off of an 88 any day of the week.
M Nut
01-31-2008 08:41:09
 Re: Best tractor in reply to dej(jed), 01-31-2008 05:37:14
Farmall M's were one of the greatest tractors ever built. That said, in the situation this gentleman is asking about, the 88 Oliver is far superior to the M Farmall. Live power and dual hyd. are nice features to have when using the tractor for farming.
Mike (WA)
01-31-2008 08:18:18
I agree that the M is a good tractor, but if he has to have dual remotes, that's going to be a problem with about anything except the Olivers. Also, Oliver has the independent PTO, and is a great tractor value for their price these days.
bradk
01-31-2008 05:44:33
Jed; Aren't operator friendly? Don't take this the wrong way,but have you ever operated an Oliver 88? There's nothin' UNFRIENDLY about it!
The "pulling tires off" thing made me laugh too.LOL
Mike M
01-31-2008 04:19:30
A John Deere 520. Pay a little more up front and you will get more later on.
Y. Lau
01-30-2008 21:02:32
A Kioti or Hinomoto would be best.
old
01-30-2008 20:44:56
I would have to agree with the Oliver S77 or 88 either one. Also either one will out pull the ford 801 hands down. I know I have an 841 and a 77 and the 77 will out pull the 841 and the 841 has a fresher engine then the 77 does.
Roy in georgia
01-30-2008 20:02:29
the DC case comes to mind on this one a friend of mine has one and it is a real brute and was told it is rated at 50 hp in the late models of the DC
J heitkemper
02-01-2008 17:32:25
 Re: Best tractor in reply to Roy in georgia, 01-30-2008 20:02:29
DC gets My Vote as well ,,, In All honesty it really depends on your situation Likes and Dislikes.. 88 are good tractor Diesel especially ,, Gasser are 6 cylindar with an Appetite when called on for power , best regards ,jim
reply
01-30-2008 19:51:29
I'd pick the super 77.
Les va.
01-30-2008 19:42:18
I would recomend the 801 ford 45hp 2or 3 remotescan be installed very avaliable and dependable
Andy Motteberg
01-30-2008 19:26:14
Go for a Farmall! Maybe a SMTA???
