Tractor Talk Discussion Forum
Hydraulic Valve ??
K-Mo
01-29-2008 06:58:13
The tilt vavle on my Mustang skidloader loads the hydraulic system. When I partially activate the valve in the down position, it puts a load on the hydraulic system. Otherwise everything works fine.
Anyone have an idea as to the cause and how to resolve the problem?
Thanks,
K-Mo
greygoat
01-29-2008 07:07:09
 Re: Hydraulic Valve ?? in reply to K-Mo, 01-29-2008 06:58:13
Is it a OEM, or factory supplied valve, or an
aftermarket valve?
Your description sounds like the valve does not
have a partial open position, but only works when
fully open. Some valve spools are machined to
give "metering", that is, the farther they open
the more the flow, and it wouldn"t cause back pressure on the system. A cheap aftermarket valve
may not have that.
