Tractor Talk Discussion Forum
hillbillyOH
kyleOH
01-28-2008 18:58:46
what is your name? you sound lke you know quite a bit about allis tractors.... i thought i knew everyone around..
hillbillyOH
01-29-2008 04:13:50
 Re: hillbillyOH in reply to kyleOH, 01-28-2008 18:58:46
I actually don't know all that much about Allis, but I was forced to learn a few things when the headgasket on our C blew last month. :) It was a great learning experience.
huntingreen
01-28-2008 19:41:02
If you can get a space heater. Set it up and let it blow on the engine and get it hot. That has worked for me in the past.
Lanse
01-28-2008 19:01:09
Hey kyle
kyleOH
01-28-2008 19:02:56
 Re: hillbillyOH in reply to Lanse, 01-28-2008 19:01:09
hiya lanse... i finally got on here.. lol
Lanse
01-28-2008 19:05:20
 Re: hillbillyOH in reply to kyleOH, 01-28-2008 19:02:56
Hey. Its comin along well. I guess you can disreguard the e-mail i sent you a min. ago, LOL :-)
kyleOH
01-28-2008 19:08:32
 Re: hillbillyOH in reply to Lanse, 01-28-2008 19:05:20
haha its ok... lanse if i were you.. id take the sheel metal off and prep that. so its done. then worry about the oter stuff... i know the engine is stuck. and i know guys have said not to jack it up on the crank.. but id do it. ive done it many times no problems.
Lanse
01-28-2008 19:15:37
 Re: hillbillyOH in reply to kyleOH, 01-28-2008 19:08:32
Yeah, im between a rock and a hard place here. I allready have the ATF and the PB so i guess i'll try that first, then go with the crank. Its partially i want to try it, old swears by ATF and others say it just wont work so theres one way to find out. I have allready sanded and primed most of er' but i ran out of primer on the back, so the back and the bottom are primed thinly or not at all.
kyleOH
01-28-2008 19:19:16
 Re: hillbillyOH in reply to Lanse, 01-28-2008 19:15:37
get the hood off.. take the head off and go from there. get you a mixture of atf,kroil,pb, and gibbs. and wait patiently ;)
Andy Motteberg
01-28-2008 20:20:24
 Re: hillbillyOH in reply to kyleOH, 01-28-2008 19:19:16
Sometimes mixing penetrating oils & fluids is not good.
