Tractor Talk Discussion Forum
ford 7.3
Dale in Ar.
01-26-2008 18:43:48
My son has found a 93 Ford 350 with the 7.3 diesel engine in it.It does not have the turbo,which I would druther have.The guy said that he got around 18 to 20 mpg before he had it rebuilt,which he just had done.Now,what kind of milage sounds reasonable for this set up ??? I am looking for something to haul my tractors with that gets decent fuel milage.My truck now gets 8 mpg,ton Chevy,454,4 wheel drive,loaded or empty.
jdemaris
01-27-2008 06:28:00
 Re: ford 7.3 in reply to Dale in Ar., 01-26-2008 18:43:48
I've got two - an 85 with a 6.9 and a 94 with a turbo 7.3. I drove many 7.3 trucks when new back in the 80s and personally never got better than 15 MPG. I hear reports of 20 plus from others though. 6.9 is the same engine as the 7.3 with a slight difference in bore. The gearing and type of trans will make a difference. Overdrive is supposed to make a big difference, but it hasn't made much of a difference with my Ford IH diesels. I take a long trip every year - mostly flat highways with a 2000 lb. pop-up camper on the back of the truck. My 85 with 6.9 (no OD) averaged 13.2 MPG, my 94 7.3 turbo (with OD) averaged 12.4 MPG, and my 92 Dodge (Gertrag OD) with Cummins 5.9 got 17.5 MPG.
My 85 F250 4WD ex-cab with 4.10 axles and C6 auto-trans (no OD) and 6.9 gets a best of 13.5 MPH empty at highway speeds and 9-10 MPG pulling a 6000 lb. traier. I took this truck on a 3000 mile trip with a 2000 lb. slide-in camper on the back and averaged 13.2 MPG for the entire trip - mostly at 70 MPH on flat highways.
My 94 F250 4WD ex-cab with 4.10 axles and E40D (lockup overdrive auto) with 7.3 IDI turbo gets a best of 14.5 at highway speeds. Best mileage it ever got was in Michigan flat-land with a wind behind us and we got 17.5 MPG at 75 MPH empty - but that's rare. I took this truck on a 3000 mile trip with a 2000 lb. slide-in camper on the back and averaged 12.4 MPG for the entire trip - mostly at 70 MPH on flat highways.
My neighbor took his on a long flat-highway trip to Florida. From here in New York to Florida is slightly downhill the whole way. It's a 94 F250 4x4 super cab long bed with a IDI TD, E40D, 4.10 gears. The truck was basically empty... one
motorcycle in the bed and pulling a jet ski on a trailer. Cruise Control set at 70mph (about 2250rpm) --> 13mpg
Cruise Control set at 60mph (about 2000rpm) --> 16.5mpg
Cruise Control set at 55mph (about 1800rpm) --> 21.3mpg
The new 2008 diesel trucks were just tested pulling a 9000 lb. trailer. All are four-door cabs and 1 ton trucks.
Chevy 6.6 Duramax won at 10.5 MPG. (18.2MPG empty)
Dodge 6.7 Cummins got 8.7 MPG (13 MPG empty)
Ford 6.4 IH got 7.6 MPG. (11.2 MPG empty)
rrlund
01-27-2008 09:24:11
 Re: ford 7.3 in reply to jdemaris, 01-27-2008 06:28:00
I'd go along with that. My 85 6.9 gets around 16 empty.
ChadS
01-27-2008 05:53:35
I have a 93 F-350, 7.3D with no turbo, had the heads and the injector pump rebuilt two years ago.. Loaded I get maybe 8 mpg, emtpy I get 12, on a good week. LOL! They have good low end torque, and if it has the 5 speed, I think youll like it. Just dont get em HOT!!! ChadS
Goose
01-26-2008 19:36:53
My brother-in-law used to have an '89 F350 crew cab dually with the 7.3 non-turbo engine. We used to borrow it all the time.
I once borrowed it to pull my 18' flatbed to Topeka, KS to pick up an Olds Ciera of my niece's that had spun a rod bearing. I got 14 mpg for the round trip. Another time we ran it empty up to St. Paul, MN and got around 18.
I don't know if this is a negative record or not, but I once hauled a '67 GTO to Minneapolis from Lincoln, NE for a fellow and pulled the same trailer with a Chevy crew cab dually, 454 gas burner. I got 6.8 mpg round trip, hauling the "Goat" to Minneapolis and pulling the empty trailer back. But--I admit I had the hammer down with the A/C on. I was trying to make time, not gas mileage.
olivergreen
01-26-2008 19:14:46
We are running 2 1990, 7.3, f-250. Pretty much identical except one is extended cab. 16, 18, 20 mpg empty not unuseal. 18 ft car trailer,3 harleys,6 guys, camping gear,extraparts for the swap meet, running 75-85 mph. 12-14mpg. The more you load & pushem the worse the milage. I won,t be happy when they give up. they have been good rides so far.
