Tractor Talk Discussion Forum
White 2-135
Mag
01-23-2008 17:03:10
I am looking at a 1987 2-135 series III front wheel assist tractor which has a loader on it. Can anyone tell me the good and bad of the 2-135 and if the front wheel assist is good or bad. The tractor has 4800 hours and a new clutch.
Thanks, Mark
Gleanerguy
01-24-2008 10:42:10
 Re: White 2-135 in reply to Mag, 01-23-2008 17:03:10
The Hercules engines are one of the most expensive engines to overhaul. Must be because there was not very many of them made compared to the Cummins and Perkins engines.
Otherwise a pretty solid tractor all around.
bradk
01-24-2008 06:26:16
Real good honest workhorse.The Hercules engine takes a little fuel,but the tractor is 137 pto horse so is bound to.
The front assist is also as good as they come.~brad
hayray
01-24-2008 03:14:57
I love the Whites, if they were painted green and yellow they would have put Deere right out of business.
rrlund
01-24-2008 06:18:22
 Re: White 2-135 in reply to hayray, 01-24-2008 03:14:57
Got that right. I traded a 40 series Deere even money for mine. I definately traded UP.
rrlund
01-23-2008 18:34:06
I've got an 82 series III. I really can't find any fault with it,unless it's fuel consumption. But it's a pretty large tractor,so you have to expect it. Neighbor has a 4430 Deere and says his uses about the same,so not just a White problem.
Mag
01-24-2008 11:48:19
 Re: White 2-135 in reply to rrlund, 01-23-2008 18:34:06
Does the 2-135 have dual pto if so is it a separate shaft?
Mark
