Tractor Talk Discussion Forum
Farmall M with antifreeze in oil
1 Dollar
01-20-2008 17:38:01
On the Framall M that I recently bought, non-running, there was a little antifreeze in the oil filter and about 1/2 a quart in the pan when I drained it just two nights ago.
I am just wanting to know if there is any common problem with cracked heads or something similar that I should look for with this engine. Anything to start looking for? One guy suggested retorquing the head, which do to 10 degree temps, hasn't happened yet.
I'm just trying to put together a game plan on how I should go about fixing this problem.
Thanks, from 10 degree central Indiana(warmer tomorrow)
Joey
Old Ford Mechanic
01-20-2008 22:39:04
 Re: Farmall M with antifreeze in oil in reply to 1 Dollar, 01-20-2008 17:38:01
I would think either a leaking o-ring around a sleeve or possibly a leaking head gasket.If it does'nt miss or run hot you can probaly eliminate the head or the gasket.To check the sleeves,pull the oil pan and install a pressure tester in place of the radiator cap.Pump up about 12 to 15 lbs of pressure and look up around the sleeves from the bottom.If one is leaking you can see it.
notadeere
01-21-2008 11:56:31
 Re: Farmall M with antifreeze in oil in reply to Old Ford Mechanic, 01-20-2008 22:39:04
hey old dont get me wrong here but M's have what we call dry sleeves so theres no O ring that i know of ? if water is coming from under sleev its a crack in the block as the sleeves just sit in a bored out hole like a car eng. just a thin sleeve is all u get
notadeere
01-20-2008 18:21:36
more then likely 2 things head gasket went bad from sitting around Or the biggie crack in the block around one of the sleave areas one fast way to tell is pull the oil pan & fill the rad back up & look up at slev areas if u see water find diff block but wait for the Other boys to give there Opinion too maybe they know more
