Tractor Talk Discussion Forum
Isolator valve massey135
andys
01-19-2008 15:10:08
Is it worth buying an isolator valve for massey 135?I wonder does anyone know if there's a certain amount of power loss because the lift arms have to go up if the valve isn't fitted which would not be the case if the isolator valve was used,its the valve which goes under the seat and means you can stop the flow to lift arms.
Gerald J.
01-19-2008 18:34:22
 Re: Isolator valve massey135 in reply to andys, 01-19-2008 15:10:08
Without out the valve you have to lash the 3 point down to use the hydraulic power remotely. I used a 3 point sprayer and pulled a planter with independent marker and lift using my 135 with valve last spring. Couldn't have done the job without the valve.
Gerald J.
